Здравеите на всички
    Първоначално публикувано от street_fighter
    няма ли да е по шумна ряботата с 10W40?
    ми аз не мисля че разбирам повече от инжинерите на алфа
    те са казали 10в40
      [quote=търтей]
      Първоначално публикувано от "street_fighter":7ayfuyph
      те са казали 10в40 [/quote:7ayfuyph]
      след 200 000 км все пак малко може да има луфтове?........само питам не спора с никой
      Alfa Romeo 1.8 TS 8v
        бе е съм му майката слагам 10W40и тва е, които иска да ме разубеждава да го направи по скоро че от много чудене ще сложа няква приста
          сори спи ми се и не ми се превежда - виж особено последната част
          Oil Viscosity
          The viscosity of multi-weight motor oil is specified using two numbers. The first number is the viscosity when the oil is cold. This is followed by the letter W (which stands for winter, not weight), which is followed by the number that indicates the viscosity when the oil is at operating temperature. The higher the number the thicker the oil.
          Viscosity Modifiers
          In order to protect an engine at start time, the oil needs to be thinner when cold so it flows freely. Viscosity modifiers are added to the base stock to make the oil flow better when cold, without making the oil too thin when hot.
          Climate Considerations
          Owner's manuals and service manuals will specify the acceptable oil to use at various temperatures. In warm climates, 10W30 is usually an acceptable alternative to the preferred 5W30 and may be used without measurable adverse effects. In the olden days, before multi-weight oils, it was common to have a winter oil and a summer oil. This is no longer necessary, but if you normally use 10W30 because you live in a warm climate then be sure to switch to 5W30 if you plan on using the vehicle in very cold weather.
          5W30 versus 10W30
          Virtually all new passenger vehicles sold in the U.S. use either 5W30 or 10W30 oil. The difference between the two is that the 5W30 flows better when cold, so if you live in a cold climate or operate your vehicle in a cold climate during the winter months, you should use 5W30 if it is the preferred oil for your vehicle. If you live in a sub-tropical climate and don't operate your vehicle in cold climates, then 10W30 is acceptable as long as the manufacturer specifies that it is permissible to use it.
          Is there a disadvantage to using an oil that flows better when cold, i.e. 5W30 versus 10W30?
          Sometimes, but usually not. The crux of the issue is this: the bigger the difference between the cold oil viscosity and the hot oil viscosity, the more the volume of viscosity modifiers and the less the volume of base stock. If you are good about following the manufacturer's recommended oil change interval then stick with the 5W30 if that is the preferred oil for your vehicle, even if 10W30 is acceptable in warmer climates. Older cars may specify 10W30 only. This is because they need a little more viscosity when cold to keep a protective film on the cylinder walls. There have been instances where the larger amount of viscosity modifiers that are present in 5W30 have broken down due to excessive heat and have left carbon deposits on the valves, but this is extremely rare. The proper fix would be to reduce the excessive heat, but the workaround was to use an oil with less viscosity modifiers.
          Why do many oil change places, even dealerships, use 10W30 instead of 5W30, even when 5W30 is preferred?
          According to www.cartalk.com (see link in the references section), as well as many mechanics who have posted on usenet, 10W30 is the closest thing to a one size fits all oil. Many older vehicles need 10W30, and most newer vehicles are okay with it in warmer climates. Since many garages don't want to have multiple tanks of bulk oil they choose to carry only 10W30. The advice that Tom & Ray give is correct, 'it would not be a disaster if you used 10W30, but given a choice, go with the manufacturer's recommendation and use the 5W30.'
          Thicker is Better Myth
          The reason that oil viscosities have gotten thinner is because bearing clearances have become smaller. Using thicker oils will interfere with oil flow and the oil pressure will increase. In a worn engine it may be okay to increase the viscosity of the oil because the bearing clearances have become larger.
            И аз ти препоръчвам 10-40 може и да го хапва повечко но поне си сигурен че няма да имаш проблеми. а за шума мога да ти кажа че поне сутрин при първото палене ще е по тиха с 10-40 защото ще пълни по бързо с масло при повдигачите, а през другото време не мисля че ще има разлика в звука освен във високите обороти когато пак 10-40 има предимство.
            А вече и на мен ми се спи дано не написах глупост.
              [quote=търтей]
              Първоначално публикувано от "street_fighter":2byh6c8s
              те са казали 10в40 [/quote:2byh6c8s]
              Инженерите на Алфа, специално за този модел са написали на лепенката под предния капак 15W40 SemiSyntetic Alfa Romeo Lubricant
              Не искам да споря, но аз моята я карам вече 3 год. с 15W40 и нямам оплакване, особено сега лятото, когато термометъра прехвърля 30*. В началото и слагах SELENIA, но го папкаше, сега слагам FINA от колегата Кирил Василев и папка по-малко (~200-250g/1000km), което ми се струва нормално имайки предвид, че понякога оборотомера се движи м/у 4-6000
                Ти пък сега, ПРИСТА
                Търтея е постнал хубава статия, но тези двигатели за които е писано там са по-нова концепция докато TS на 155 8V е стара концепция, който се слага и на 75 и 164. От друга страна колите които караме са над 200К км и над 10-11г. за да се притесняваме от 15W40. По-гъстото масло уплътнява по-добре луфтовете, които имат моторчетата ни Но всеки си има право на лично мнение и предпочитание
                УСПЕХ!
                п.с. ЧЕСТИТО и със здраве да си я караш
                  Първоначално публикувано от Dodo 155
                  е да но ти прецаква студения старт а колата най-много се износва именно тогава
                  затова ако имам парици бих слагал 0в60
                  иначе си прав де сичко е до личен вкус
                    Износването на мотора е до 80% при студен старт, независимо дали е нова или стара кола Това не идва от вискозитета на маслото, а от "сухите" части в двигателя Вярно, че по-тънкото масло отива по-бързо по частите, но разликата м/у 10W40 и 15W40 е малка, а и луфтовете са по-големи вече
                    Има и нещо друго - валовете на 155, както и на повечето италянки са във вани, т.е. винаги има масло, така студения старт е преборен донякъде
                    Но както си реши колегата, каквото и хубаво масло да сложи на колата няма да съжалява за покупката
                      тука Додо малко грешиш
                      функцията на маслото е да маже
                      маслото не може да уплътнява
                      единственно могат да му се слагат добавки да има по-големи почистващи функции
                      както е казал и търтея може би 0W60 е най добре
                      както знаем първата цифра показва при каква най-ниска температураа, а втората показва при каква най-висока температура си запазва качествата
                      сега нямам възможност да намеря, но ще потърся и постна по-късно характеристиките на маслата
                      ИТАЛФЕСТ 2004 - "Барабар Петко с мъжете"
                      :biker: ИТАЛФЕСТ 2005 :biker:
                      • #26
                        В БМВ форума има много хубава статия за маслата.
                        http://bmwpower-bg.net/forums/viewtopic.php?t=4715
                        • #27
                          Първоначално публикувано от hf hpe
                          Съгласен съм с теб, малко неправилно се изразих, че уплътнява, имах предвид, че мотора харчи по малко по-гъстото масло защото е по-плътно (по-висок вискозитет).
                          А иначе и 15W40 смазва, но смазва съответните двигатели. За твоя мотор ще е кущунство да го караш с такъв вискозитет, но аз рядко я ръчкам моята и много рядко я вкарвам над 5000 обор. Четох някъде преди време, че не е много препоръчително да се слага както и по-гъсто, така и по-рядко масло от това което препоръчват. По-гъстото ясно защо, но с по-рядкото масло помпата не може да компенсира налягането. Т.е. маслена помпа, която е изчислена за определен дебит при даден вискозитет и да направи съответно налягане, не може да изпомпа повече количество от рядкото масло, за да компенсира до нужното за мотора налягане. Дано се изразих правилно
                          • #28
                            Абе как ви горят толкова масло тея алфети
                            Аз карам 155 на 275 000 км реални и доливам по макс 100грама на месец със Selenia 20k for Alfa Romeo. Даже последно се падна на два месеца...
                            Alfa Romeo 155 1.8TS
                            Alfa Romeo 156 1.9 16V m-jet
                            • #29
                              Първоначално публикувано от ALFA CORSE
                              Братле аз от три месеца ни масло ни бензин съм наливал
                              Добре че седи у бокса
                              • #30
                                Първоначално публикувано от valjo
                                Селения за Алфа Ромео си има отделен продукт "Selenia 20k for Alfa Romeo" - който се сменя на 20000 км , полусинтетика
                                и който го гори много обаче
                                голд пак е полусинтетика и пак на 20к се сменя но не го гори толкова
                                аз от както съм закупил моята кола до сега съм я карал само със Selenia Gold и да си кажа чесно доста си го погорва....някъде около 1,5-2л на 10к(в зависимист от напрежението )сега за сефте налях 20к, още нямам наблюдения за него защото съм изминал едва 1,5к с него, но силно ме съмнява че ще го гори повече от голда
                                а и още нещо на голда му дават 15 000к max, а на 20к 20 000к max, но всички знаем че това си е малко пунтамара при нормални експлотационни условия е съвсем нормално маслото да бъде сменено на 10к.
                                ALFA ROMEO 155 T.SPARK 2.0 8V
                                ALFA ROMEO 33 1.5 TI
